12-30-2002 04:33 AM - edited 03-09-2019 01:31 AM
Hi all! Trying to configure CBAC on 2610 running IOS ver.12.2(2)T. My Cisco reseller insists my platform supports the Cisco IOS Firewall Feature set. However, whenever I issue the command ''show ip inspect all'' to verify the CBAC capability, the output shows that the CBAC is not supported (% Invalid input detected at '^' marker)! Any comment/help will be appreciated!
Thanks.
Joe P.
12-30-2002 05:54 AM
Hi Joe,
What we need to do is check the actualy image you are running with a "sh version" off the router.
You should have this image:
"c2600-io3-mz.122-2.T.bin".
Please post us the image name and we can take it from there.
R/Catherine
12-30-2002 07:11 AM
Dear Catherine,
The most relevant info from the 'sh ver ' output is as follows:
*system image file is 'flash:c2600-i-mz.122-2.T.bin'*IOS (tm) C2600 Software (C2600-I-M), Version 12.2(2)T, RELEASE SOFTWARE (fc1).
Should you need any other detail, kindly let me know.
Regards.
Joe P.
