Changing Syslog Severity Levels
unionbancorpit
I would like to change the severity levels of specific messages. I can do this on the PIX with the "logging message" command. I need to do the same thing on our 1750, 2600 and 7200 routers. Is this possible? Thanks.
spremkumar
Level 9
Level 9
hI
In routers u can use logging buffered or host name (syslog server ip) for different levels of messages.
for ex:
alerts (severity=1)
critical (severity=2)
debugging (severity=7)
emergencies (severity=0)
errors (severity=3)
informational (severity=6)
notifications (severity=5)
warnings (severity=4)
regds
prem
unionbancorpit
What I want to do is log all warnings except for 1 specific warning message. On the PIX I can use "no logging" or change the severity of a specific message. I have it configured to only send warnings or higher priority but there is 1 warning message that I don't want to see.
i also need to change the severity of some specific messages - example: %C6KPWR-SP-4-PSFAIL -> %C6KPWR-SP-2-PSFAIL
