10-15-2008 06:42 AM - edited 03-09-2019 09:40 PM
I have a problem when I'm connected via WebVpn Portal on my ASA 8.0(2) to access to my shared folder.
If i use with my cisco vpn client install on my computer i can access to my shared folder.
Have you ever meet this problem?
10-21-2008 10:39 AM
The clientless version of webvpn doesnot support sharing of files and folders. you need to use the any connect vpN client and configure the ASA for the Anyconnect vpn client.
10-22-2008 12:07 AM
I think your wrong.
I've already configured CIFS shared access on ASA 8.0(1) (without Anyconnect) like a resource on Webportal and it's working !
And it was working with SSO on an active directory. The authentication used for the webportal was used for the CIFS share.
The only problem I encountered was a bug (CIFS doesn't work after a certain time) which is fixed in 8.0(3) or 8.0(4).
