10-20-2008 01:32 AM - edited 03-09-2019 09:42 PM
We have a EasyVPN setup with Headend as ASA and clients are cisco 878 ADSL routers.Pc's are connected to the ADSL routers and these PC's are accessing our inside servers without any issues.
But to get the RDP access to those PC's from our Inside network we have to reset the isakmp or need to restart the router each time .
Please help us to solve this issue .. Why this issue only for RDP access and rest all applications are working without any issues.
Below the access-list for RDP access
access-list Split_Tunnel_List extended permit tcp 172.16.128.0 255.255.255.0 eq 3389 172.19.0.0 255.255.0.0
Aslam ...
10-20-2008 01:51 AM
why is rdp port 3389 as source port??
I think it should be destination , could you try change access-list to
access-list Split_Tunnel_List extended permit tcp 172.16.128.0 255.255.255.0 172.19.0.0 255.255.0.0 eq 3389
M.
Hope that helps rate if it does
10-21-2008 09:02 PM
Hi ..
Thnx for the reply ...but in access list that is the Source port. 172.16.128.0 is our inside network. If i change to the otherway i cant use the RDP
Aslam ..
