CIFS with WEB Portal
mathieuchanu
I have a problem when I'm connected via WebVpn Portal on my ASA 8.0(2) to access to my shared folder.
If i use with my cisco vpn client install on my computer i can access to my shared folder.
Have you ever meet this problem?
bwilmoth
Level 5
Level 5
The clientless version of webvpn doesnot support sharing of files and folders. you need to use the any connect vpN client and configure the ASA for the Anyconnect vpn client.
I think your wrong.
I've already configured CIFS shared access on ASA 8.0(1) (without Anyconnect) like a resource on Webportal and it's working !
And it was working with SSO on an active directory. The authentication used for the webportal was used for the CIFS share.
The only problem I encountered was a bug (CIFS doesn't work after a certain time) which is fixed in 8.0(3) or 8.0(4).
