04-16-2003 03:38 AM - edited 03-09-2019 02:55 AM
Hi there,
I try to establish VPN connection between Cisco router and FreeS/WAN on Linux machine.
On cisco 831 I have IOS 12.2 FW/3DES and on linux FreeS/WAN version1.96.
I use preshared keys.
On Linux side I receive this error :
protocol/port in Phase 1 ID Payload must be 0/0 or 17/500 but are 17/0
Debug on cisco site shows this:
02:31:52: ISAKMP (0:1): Send initial contact
02:31:52: ISAKMP (0:1): SA is doing pre-shared key authentication using id type
ID_IPV4_ADDR
02:31:52: ISAKMP (1): ID payload
next-payload : 8
type : 1
addr : xxx.xxx.xxx.xxx
protocol : 17
port : 0
length : 8
02:31:52: ISAKMP (1): Total payload length: 12
Can someone help!
Thanks you
04-16-2003 09:22 PM
Not sure anyone in Cisco has tested this. Found this (http://www.diverdown.cc/vpn/freeswanciscorouter.html) in Google, it may be of help. there's a bunch of other stuff if you search for "cisco freeswan vpn ipsec".
04-21-2003 10:08 PM
I look at the google, I also post some questions to mailing lists.
I got this answer:
The Cisco appears to have a buggy IPSec implementation:
RFC 2407, section 4.6.2 states :
During Phase 1 negotiations, the ID port and protocol fields MUST be
set to zero or to UDP port 500. If an implementation receives any
other values, this MUST be treated as an error and the security
association setup MUST be aborted.
So the Cisco is proposing UDP port 0, which according to the RFC is invalid.
Darjo
06-26-2003 01:21 AM
Is this connected with IOS version. Is there any patch for this behavior.
08-16-2003 10:16 AM
i've get grey hair with this problem with a cisco 836 an ios 12.2(13)ZG. It's a buggy implementation of the isakmp protocol by cisco
RFC 2407 says:
4.6.2 Identification Payload Content
The Identification Payload is used to identify the initiator of the
Security Association. The identity of the initiator SHOULD be used
by the responder to determine the correct host system security policy
requirement for the association. For example, a host might choose to
require authentication and integrity without confidentiality (AH)
from a certain set of IP addresses and full authentication with
confidentiality (ESP) from another range of IP addresses. The
Identification Payload provides information that can be used by the
responder to make this decision.
During Phase I negotiations, the ID port and protocol fields MUST be
association setup MUST be aborted. This event SHOULD be auditable.
so, protocol must be 17 (UDP) an port must be 500, not 0!!!
1 week ago i've got an ios-security update, which upgrades me to 12.2.13 ZH2.
With this ios, the preshared key auth runs with freeswan. they've fixed the bug ! It run's with no problem
But i need rsasig, and that doesn't run :-(.
Cisco send an isakmp-header with 156 byte length, but isakmp needs only 28!! Perhaps you know a solution
I think cisco implements the ipsec-standards in a way, that only cisc - cisco ipsec runs :-(
Hope this helps
Andreas
