CISCO MERAKI MX84
amalmichaelvj
How many WAN can be connected to cisco meraki mx 84?And what is maximum speed supported?
2 Accepted Solutions
nspasov
Hi there. I would suggest you check out the data sheet for the MX84 appliance:
https://meraki.cisco.com/products/appliances/mx84#compare
I hope this helps!
Thank you for rating helpful posts!
nspasov
I hope this helps!
Thank you team,
And for the speed you should also check the sizing guide:
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_mx_sizing_guide.pdf
