Cisco IPS 4260 Sensor
may272007
Hi Team,
Need advice or steps to do factory reset on Cisco IPS 4260 Sensor. Current device is not in support, hence can't raise any TAC case in this case.
I need steps to do factory reset. its bit urgent, any help would be much appreciated.
BR,
Rohit
Marvin Rhoads
recover application-partition
That will delete everything except the few network settings (ip address, gateway netmask etc.)
Reference: http://www.cisco.com/en/US/docs/security/ips/5.0/configuration/guide/cli/cliimage.html#wp1060091
Hi Marvin,
I am not able to login to this device, hence can't run the command. Is there any other way we can do a factory reset. I do know there is some button, but not able to recollect this for this device.
Can you confirm if there is any factory reset button for this device, so that i can use that.
Br,
Rohit
There is no factory reset button on any of the Cisco IPS sensor appliances.
