CISCO NEXUS 5548 (5K) Login-Block command not found
Frank27
I have a problem with a CISCO 5548 switch . I cannot find the login-block command.
System version: 7.0(2)N1(1)
In global configuration mode there is no login-block command, neither under system login block-for or in the aaa  subsystem menu.
As per example :
(config)# aaa authentication rejected 3 in 20 ban 300
% Invalid command at '^' marker.
Followed these indications :
https://www.cisco.com/c/en/us/support/docs/csa/cisco-sa-nxos-login-blockfor-RwjGVEcu.html
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/security/configuration/guide/b-cisco-nexus-9000-nx-os-security-configuration-guide-93x/b-cisco-nexus-9000-nx-os-security-configuration-guide-93x_chapter_011.html
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/security/configuration/guide/b-cisco-nexus-9000-nx-os-security-configuration-guide-93x/b-cisco-nexus-9000-nx-os-security-configuration-guide-93x_chapter_011.html#task_794D196F...
I need to activate the login-block (QUIET MODE) for ssh.
Any idea regarding?
balaji.bandi
check is this may be a bug referencing to nexus 9K - but worth checking.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvf86915
BB
Workaround: Replace "login block-for" and "login quiet-mode" with "system login block-for" and "system login quiet-mode", respectively. Use "show system login ..." for relevant show outputs.
Nothing, these commands are not implemented .
