12-27-2022 11:01 PM - edited 12-27-2022 11:11 PM
I have a problem with a CISCO 5548 switch . I cannot find the login-block command.
System version: 7.0(2)N1(1)
In global configuration mode there is no login-block command, neither under system login block-for or in the aaa subsystem menu.
As per example :
(config)# aaa authentication rejected 3 in 20 ban 300
% Invalid command at '^' marker.
Followed these indications :
https://www.cisco.com/c/en/us/support/docs/csa/cisco-sa-nxos-login-blockfor-RwjGVEcu.html
I need to activate the login-block (QUIET MODE) for ssh.
Any idea regarding?
12-28-2022 12:07 AM
check is this may be a bug referencing to nexus 9K - but worth checking.
12-28-2022 12:34 AM
Workaround: Replace "login block-for" and "login quiet-mode" with "system login block-for" and "system login quiet-mode", respectively. Use "show system login ..." for relevant show outputs.
Nothing, these commands are not implemented .
