Clean Access design
JASON ANDERSON
I'm working on a Clean Access design for a small college. Does anyone have any good resources for design, specifically for supporting approx. 1000 users? I'm also looking for part numbers but have only found one so far.
Thanks!
5 Replies 5
matt.austin
Well, if you haven't read ask the expert yet, that may be a good place to start. For some beginning information:
Cisco Clean Access requires 2 needed components, and one optional component.
1. Clean Access Server
2. Clean Access Mananger
3. Cisco Clean Access Agent (Optional)
I received pricing on this from http://www.cdw.com. When you look on there page, do a search for Cisco Clean Access. There prices were lower than what my Cisco Rep. had given me. A good link for information is: http://www.cisco.com/en/US/products/ps6128/, for starters. As far as performance questions and the like, let me know, I have dug into this quite a bit, and have an enormous amuont of information about the product.
Good Luck,
Matt
Hi Matt,
I do have some requirements for 4000+ users. How can I speak to you about the performance requirements and the deployment mode for such a scenario.
Hello!
CAS performs up to 1Gbps throughput with gig interfaces on eth0 and eth1. Eech CAS can support up to 1500 users (our recommended number).
a. The user count is concurrent number of users, not total number of users.
b. CCA has been deployed in many environments with over 5000 concurrent users. Multiple CASes are deployed in such a network. Mutilpe CASes can be centrally located in the distribution or even the core switch layers.
c. CCA can support the concurrent users for L2 users or L3 multi-hop users.
Nick
If anyone has any thoughts or suggestions send them our way please.
We are currently trying to implement the NAC appliance as well and are having "problems" putting it mildly. Even working with TAC we have come up short.
The scenario is a campus environment with one central 6509 distributing VLAN's for the campus. What they are requesting is 2 VLAN's to be forced to go through the applaince. We have configured device in a virtual gateway mode.
The problems we see are:
1. we get a DHCP address and get forced to the appliance O.K. but from there we can not get to any websites or even ping the DHCP server we got the address from.
2. The clean access download process from the appliance is modem speed slow. 12 - 20k. (Duplex and speed setting have been checked)
Any suggestions or guidance would greatly be appreciated.
Charles,
Did you ever make any headway on the issues you were having? We have an identical set up and I want to avoid these types of issues. Thanks!
