Command not shown under interface config
rafail.sharifov
Frequent Visitor
Frequent Visitor
Hi, Community
I am inserting command "ip nhrp shortcut" and "ip nhrp map multicast dynamic" under tunnel interface but when i exit global config and show run interface tunnel, the configs i newly inserted is not shown
2 Accepted Solutions
balaji.bandi
show run all ( do you see the config ?)
what is the device model ?
what version of code ?
BB
@rafail.sharifov
Those commands are default on newer IOS-XE code (no need to configure them), you'd need to view the full configuration using show run all in order to confirm those commands are configured correctly.
balaji.bandi
BB
@rafail.sharifov
rafail.sharifov
Frequent Visitor
Frequent Visitor
@Rob Ingram , @balaji.bandi  Thank you guys. "Show run all" show that command on router.
