command to clear ACL hit count and interface stats
afniwan
Does anyone know of a command to clear the HITCOUNT on an ACL list and a command to clear the counters on an interface for the PIX? I can't seem to find this anywhere. Any help would be appreciated. Thanks.
Jeff
jmia
Level 7
Level 7
Try command:
> clear access-list counters
This clears the counters shown by the show access-list command.
To clear counters on an interface, go into config mode and issue this command: clear int ethernet0
(You must be in config mode for this command to work.)
To set speed/duplex, again go into config mode and issue this command: interface ethernet0 100full
Also, the following URL might be of interest...
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a0080172786.html#1112250
Hope this helps - Thanks, Jay
mathia5
to clear the interface counters use
clear int ethx
On ASA version 9.0 use
clear access-list (access-list/group-name - ie. dmz_in,inside_in etc) counters
jmia
Level 7
Level 7
Try command:
That worked! Thanks. Strange that you have to do it in config mode rather than priv. exec. (enable mode) and that is what I was doing wrong. Have a good one!
Jeff
