05-12-2004 10:52 PM - edited 03-09-2019 07:21 AM
Do not with nat can I connect the inside network and the outside network,and the outside host can
see the real ip address of the inside host?
05-13-2004 12:46 AM
Use
static (inside,outside) 10.0.0.0 10.0.0.0 netmask 255.0.0.0 0 0
command to enable access to your 10.0.0.0/8 inside network.
I was told
nat (inside) 0 access-list 101
where access-list 101 defines accessible range of your inside network should work, but it didn't seem to work.
Milan
05-13-2004 09:13 AM
with the nat 0 command you have to use an access-list
command at the outside interface,too.
Zdenek
