Export Of IDS4210 and 4215 System and Signature Configs
rbansley
For audit and configuration comparison purposes, the ability to export sensor system and signature configuration settings is a requirement. How is this accomplished now that Cisco has migrated to the abreviated IOS on the 4.X version of these systems? A simple text file of the "show config" output is sufficient if possible.
marcabal
You can use the copy command on the sensor to copy the config to an ftp or scp server:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids10/cmdref/15599ch2.htm#377910
