CPU
LuvMacheen
Community Member
At what CPU utilization on my PIX should I start getting nervous?????
It appears to be running at 50% right now...
spremkumar
Level 11
Level 11
hi
If its continuning to show the utilisation as 50% althroughout then i would suggest to check out the process which uses the CPU.
You can check the same using show processes command on the CLI.Also refer this links for more info and help.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008009491c.shtml
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008009456c.shtml
regds
