04-28-2006 04:57 AM - edited 03-09-2019 02:45 PM
We're running a MARS 100E and have created a seed file to mass import 120 IOS routers. The seed works great and imports the devices but then we must go through each device and discover it. This is needed to discover the interfaces and attached networks. Is there a way to discover all the nodes that I have just imported without manually going through each node? Thanks for any help!
-Mike
05-02-2006 05:21 PM
You might try:
Admin -> Topology/Monitored Device Update Scheduler
to see whether it will do your job. My guess would be that it would depend upon whether the subnets from the seed file were successfully imported.
05-03-2006 07:52 AM
Thanks... that did it. I scanned the entire WAN subnet of the routers I used in the seed file and within an hour it had imported all the configurations. Thanks for the help!
