Lotus iNotes through WebVPN
chris-davidson
Is anyone successfully using Lotus iNotes and WebVPN ? We are using Domino 7 through a VPN Concentrator running 4.7.2.F. When we try to access any messages in iNotes we see the following Domino error. "Domino Web Access Warning. Sorry, we are unable to process your request at this time. If you are unable to continue working in your mail file, please dismiss this warning and then select View, Refresh from your browser's menu"
Concentrator logs show numerous errors. "Closing socket # for invalid connection"
Any ideas ?
a-vazquez
Level 6
Level 6
I think it looks like a bug, you can avoid the issue by using IPSEC vpn client or SSL VPN Client.
release notes for 4.7.2 (our latest version) and actually Domino v6.5.4 is not supported....
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_7/472con3k.htm#wp226946
wmblake755
we have the same issue, looking for some kind of resolution.
