04-25-2005 01:55 PM - edited 03-09-2019 11:03 AM
I did the upgrade to VMS 2.3 and then installed the CSAMC 4.5. The upgrade seemed to go ok, although it didn't like my license files for some reason. These were reinstalled after a reboot without an issue.
I get the 2 MC's for CSA 4.0.3 and for 4.5. I created a scheduled upgrade in the 4.0.3 MC to automatically upgrade my clients to 4.5. (did this when i went from 4.0.1 to 4.0.3 which worked a treat.
However, I'm getting a problem with the upgrades. Clients security is enabled and client seems to poll, but doesn't get upgraded. When i check the log files out from the 4.0.3 client, it talks about an issue with the certificate when communicating with the VMS server. Any one had a similar issue and got a workaround?
I manual upgrade works fine and the 4.5 client polls without an issue.
TIA
D
04-29-2005 10:47 AM
What is the exact error message that it shows in the log ?
05-01-2005 11:28 AM
I'll check one of the logs on Tuesday and post back. Monday is bank holiday here in the UK.
regards
D
05-04-2005 05:07 AM
