CSA 6.0.1 - Force Polling
I've got a large number of clients (~1500) with the UI disabled, I'm looking for a way (from the client) to force a poll. Ocassionally I'll get a client that thinks there isn't a new package, and the server thinks the client has the latest package. The only way I know around this right now is to create/modify a rule and re-generate. I'm hoping for a simpler process.
Agents with the UI enabled can click the poll button, but what to do with agents without it?
James
jan.nielsen
Level 7
Level 7
I believe that if you go to the host details in csamc and select the reset function, and just select reset system state, it will do a poll hint to that machine. You can also use the csamc api to manually do a poll for a specific host.
