08-20-2004 07:02 AM - edited 03-09-2019 08:32 AM
I've just upgrades the CSA MC from 4.0.2 to 4.0.3 build 717, and I now can't access the MC from anywhere other than the server itself. I get the following error in the CSA MC window when I try to open it:
Invalid Session
A valid CiscoWorks session is required to access the Management Center for Cisco Security Agents.
Login to CiscoWorks
I can only get into the MC by going to the server and using 127.0.0.1 in the URL. Using the server's actual IP address gives the error above even when on the server itself.
Has anybody else seen this?
Cheers
Stuart
08-30-2004 12:13 PM
Probably, if you paste the error exactly, it would be helpful to understand the problem better. You can print screen and attach it to this post.
09-01-2004 12:40 AM
Fixed it by uninstalling CSA MC (backing up the database) and reinstalling it.
Cheers
Stuart
09-29-2004 07:02 AM
I just ran into the same problem. Is there any other way to fix it besides reinstalling the MC?
