Default time for IDM to block hosts
tcavdar
In IDS 4.0 what is the default time for IDM to block hosts(in access-list for a router)?And this time is configurable?
From the sensor CLI:
config term
service virtual-sensor-configuration virtualSensor
tune
shunEvent
ShunTime (minutes to block hosts)
From IDM:
Click Configuration
Click Blocking
Click Blocking properties
Update the Block Time input control.
Note: This was recently added to IDM, so you may need
to upgrade to the latest IDS software.
tcavdar
I have learnt that it is 30 minutes...
How can i change it?
config term
tune
shunEvent
From IDM:
Click Configuration
Click Blocking
note that this affects ALL signatures. When you apply it, your sensor will have to generate new cache files..so it will act just like if you tuned a sig.
