Problems with cisco 1720
fmatarranz
Helo.
I have a Cisco 1720 wifh 2 ADSL WIC. I need to balance the trafic from my LAN through my 2 ADSL Lines.
Anybody can help me?
rwiesmann
Level 4
Level 4
What is your routing in place?
Static?
Dynamic? ==> What Protocol?
Roger
Static.
Just add twice the same static route with each one using a different next hop
and also both having the same admin distance. Like
ip route 192.168.1.0 255.255.255.0 172.16.25.1 100
ip route 192.168.1.0 255.255.255.0 172.16.25.5 100
That should work.
They way back you have to implement it on the upstream router.
Hope that gives you an idea.
Roger
