Deny udp reverse path check
pannick
I am a lot of of Deny udp reverse path check messages on my PIX from multiple IP sources to 255.255.255.255 on interface outside. I can not figure out what is causing it and how find more info.
Any tips, help or info would greatly be appreicated.
jp
Hello Joel
A tip , maybe you can enable syslog messages and chek the system log messages
go to configuration mode (I assume you already did this)
! go into config mode
conf term
!see if you are alerady logging
sh logging
!set logg to monitor everything
logg monitor 6
! or set logg to console
logg console 6
!then enable messages to telnet or ssh
terminal monitor
!start logging
logg on
!to stop logging
no logg on
Post messages or search them at
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_system_message_guides_list.html
there you will find the Error and System Messages Guides for every version available by message number
Hope this helps
Thanks for the info but I am already logging to a kiwi syslog server my error code is PIX-1-106021 by that .pdf that you mention my fear is right I am getting spoofed, or an attempt.
What I need to know it I see this with 6 or 7 different IP address. Are they all being spoofed or do I have one source doing it? How the heck do I tell the actual source of this? Each machine is an aactual IP in my subnet range, a couple or servers and a couple are workstations.
I am running ip verify reverse-path on each interface, hence why the packet is getting dropped.
I just want to find the source or sources and stop it.
Thanks again
pannick
Believe it or not I finally found it. We have a Trend virus wall that is causing it. It has something to do with the external port. I am trying to figure it out after finally tracking it down.
