09-19-2002 08:16 PM - edited 03-09-2019 12:23 AM
That might be a very silly question.
We have ordered PIX515-R-BUN however when I run show version command on our PIX it shows that its a PIX515E. I will appreciate someone can advice whats the difference between both of the mentioned models of PIX.
Second question; is their any Cisco webpage where I can give product serial # and it will display the complete details of the product.
Output of show version
Hardware: PIX-515E, 32 MB RAM, CPU Pentium II 431 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is 0009.b7b9.3f67, irq 10
1: ethernet1: address is 0009.b7b9.3f69, irq 11
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES: Disabled
Maximum Interfaces: 3
Cut-through Proxy: Enabled
Guards: Enabled
Websense: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
ISAKMP peers: Unlimited
Serial Number: 406222225 (0x18367591)
Activation Key: 0xdafb5bc8 0x34f157d2 0xb9ad4317 0xf3df7dbc
Khurram
09-19-2002 09:00 PM
The 515E is the newer version of the 515. The PIX515-R-BUN you purchased just means a 515 with a restricted licence. 515's are no longer being shipped, so you now get a 515E which is faster, stronger, better than the 515.
See http://www.cisco.com/warp/public/cc/pd/fw/sqfw500/prodlit/p515e_ds.htm
As for the web page, I don't believe there's one, but the "sho ver" output you have above gives you what hardware you have (515E with two interfaces, 32Mb RAM and 16Mb Flash), what software features you're licenced for. Not much more to tell.
09-19-2002 10:25 PM
additional question.
If I have PIX515 and order PIX515 failover bundle I will get a PIX515E, will failover work and is this supported?
09-20-2002 06:41 AM
No, you can't do failover to unlike models. Read the documentation on the 515e.\
geoff
