Disabling tcp conn timeout based on IP address
dennis
Is it possible to disable the conn timeout value for a connection from a single IP address while allowing the value set in the timeout command for all other connections? I have a connection that needs to stay active even if there is no traffic for several hours but do not want to increase the default connection timeout value on the PIX.
gfullage
No sorry, you can't do this. Timeout values are global.
What are impacts and percussions if the timeout is disabled? What are the security risks?
