04-26-2006 02:30 AM - edited 03-09-2019 02:43 PM
I am working in a datacenter setup where i need to access my DMZ servers in 10.1.14.0 subnet from inside network like 10.1.8.0. When i call the dmz servers with the public ip iam not able to reach whereas when i call with its real ip i am reaching all the dmz servers.
i have tried the alias command for a test case to map the public ip to my dmz real ips and find things working fine, ie iam able to reach my dmz servers with public ip,
but unforunately as iam using asdm, asdm does not supports alias command now i have to use the outside nat or bidirectional nat feature for this functionality.
can any one help me out how do i configure destination nat that is when i access the dmz servers from inside network with the public ip i need it should get natted to private ip as well i should be able to reach this dmz servers with its real private ip
Thanks in advance
The alias command that i tried is
alias (inside) 10.1.14.25 210.212.x.x netmask 255.255.255.255
04-26-2006 04:02 AM
You could try from the command line:
1.- nat (dmz,inside) 10.1.14.25 210.212.x.x netmask 255.255.255.255
04-26-2006 04:04 AM
oops ..
I meant to say
static (dmz,inside) 10.1.14.25 210.212.x.x netmask 255.255.255.255
04-26-2006 09:20 PM
No it doesnt works, if i add this line i loose even my private ip access that is 10.1.14.25
what is outside nat or bidirectional nat and how do u configure it. pls reply if u have come across
thanks in advance
regards
Parthiban
04-27-2006 05:24 AM
BAsically Outside nat applied to traffic from lower security interfaces (i.e outside ) to giher security interfaces ( i.3 inside ).
Static (dmz,inside) 10.10.10.10 203.203.203.203 netmask 255.255.255.255
indicates that the hosts 203.203.203.203 which is located on the dmz segment ( lower security ) appears as 10.10.10.10 to the inside segment (higer security ).
I suggest you tohave a look at this link which gives a great explanation in regards to teh different types of nat.
05-02-2006 03:40 AM
I suppose that the translation command would be instead like that:
static (inside,dmz) 10.1.14.25 210.212.x.x netmask 255.255.255.255
(Ensure that you put ACL on inside interface permitting traffic from DMZ to INSIDE
Access-list MyACL permit host 210.212.x.x 10.1.8.0 255.255.255.0
access-group MyACl in interface inside
MAy be it could work. Please Tell me if it works. For me it's a real excercise as I'm preparing SNPA exam. Good luck
