Encrypting a site-to-site direct leaseline connection
robin
I wld like to know how i can configure the above with 3DES encryption, can't seem to find a sample on the web.
Thanks in advance.
cbettam
Hi Robin
This is a very open question. presuming you're using cisco products, all concentrators(gui based in design but cli too) support 3des as do most routers/firewalls. A good starting point giving links to VPN enabled products is-
http://www.cisco.com/en/US/products/hw/vpndevc/index.html
from there, each solution has given examples
good luck
Sorry, perhaps, i didn't make it clear, i'm refering to configuration of the 2 connecting routers that can support 3DES.
rdgs
Here is the URL that you are looking for:
http://www.cisco.com/warp/public/707/overload_private.shtml
You can use 3DES in the isakmp policy and transform set instead of DES.
Arul
