Encryption Connection only lasts a maximum of 20 min.
Mark_Matthias
In attempting to set up encryption between a 2520 and a 4500, I am unable to keep an encryption connection active for more than 20 min.
Initially, I was only able to keep the connection active for closer to 10 min.
When the encryption connection fails, I am unable to email or ftp across the T1 link.
The 4500 shows that there is a connection in place with a proper Connection ID. The 2500 indicates that it is attempting to renegotiate a connection, showing negative numbers.
I am using IOS version 11.2 on both routers with the same feature set.
Both routers share the same time and time zone. Neither pregenerates keys. There's no other connetction between the two routers.
In order to get the link active again, I have to delete the crypto maps from the interface, delete the crypto maps globally, create new ones with a different name,clear any exiting crypto map ids and apply the new maps to the T1 interfaces.
From the Routers when failed................
2520#sho crypto conn
Pending Connection Table
PE UPE Timestamp Conn_id
10.0.0.0 10.0.0.0 1084215551 -210
Connection Table
PE UPE Conn_id New_id Alg Time
10.0.0.0 10.0.0.0 -210 63 0 0
flags:XCHG_KEYS ACL: 129
2520#sho crypto eng conn a
ID Interface IP-Address State Algorithm Encrypt Decrypt
4500#sho crypto conn
Connection Table
10.0.0.0 10.0.0.0 10 0 11 47825
flags:TIME_KEYS
Both routes have/use the same access list ...
access-list 129 deny tcp 10.0.0.0 0.255.255.255 eq telnet 10.0.0.0 0.255.255.255
access-list 129 deny tcp 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255 eq telnet
access-list 129 permit tcp 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255
access-list 129 permit udp 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255
Any ideas how I can get this to work?
Mark
smahbub
Level 6
Level 6
Try upgrading the IOS, it might help you.
