encryption
eoscar
I would like encrypt certain traffic. Can my current HW support an image that would allow me to do this? IF any, besides upgrading the image, what else would you upgrade?
Thanks in advance
System image file is "flash:c2600-i-mz.120-8"
cisco 2610 (MPC860) processor (revision 0x203) with 26624K/6144K bytes of memory
Processor board ID JAD03412429 (2887954722)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
sh flash
System flash directory:
File Length Name/status
1 3417832 c2600-i-mz.120-8
[3417896 bytes used, 4970712 available, 8388608 total]
nihal.akbulut
Level 5
Level 5
your sw doesn't support ipsec. You have to upgrade, but your flash (8M) is very small size, I am not sure that you can find an ipsec image for that size.you can use feature navigator tool for choosing an image.
www.cisco.com/go/fn
msimonetti
Community Member
Hi, If you have a Cisco 2501 or similar instead Cisco 2600 you can use Ipsec with this HW requirements.The Cisco 2600 has a high requirements of HW always more than the 2500.
I have running IPSec with 4 Mb of SDRAM and 8M of Flash memory on the 2500.
If you can try it !, but it is not 3DES
Thnks,
I have the 2610 and will be purchasing additional memory. I will use an ipsec with des or 3des to encrypt the traffic depending on the performance. I also have rip running on the routers and would encrypt the entire traffic between sites.
