08-27-2012 02:37 PM - edited 03-09-2019 11:54 PM
I am trying to understand why my ASA appears to be dropping packets with the following message
%ASA-4-108004: ESMTP Classification: Dropped connection for ESMTP Request from inside:1.1.1.1/1292 to DMZ:2.2.2.2/25; matched Class 31: cmd RCPT count gt 100
My understanding is that the "RCPT count gt 100" drops connections if the number of recipients is gt 100. I have a wireshark trace of this transaction and there is only 1 recipient on this email.
This makes no sense to me. Why else would I be seeing this message if the number of RCPT To addresses is 1? Does this have anything to do with the number of length of the RCPT TO email address?
Thanks.
08-28-2012 06:47 PM
Can you paste your class-map and policy map output here?
08-29-2012 06:17 AM
policy-map type inspect esmtp esmtp_map
parameters
match cmd line length gt 512
drop-connection log
match cmd RCPT count gt 100
drop-connection log
match body line length gt 998
log
match header line length gt 998
log
match sender-address length gt 320
drop-connection log
match MIME filename length gt 255
drop-connection log
match ehlo-reply-parameter others
mask
08-29-2012 06:19 AM
The output I see is in the original message (so I don't have to go retrieve it again ). The map is the same as the default ESMTP inspection map except I removed "drop-connection" from the "match header line length gt 998" while we do some testing.
