Expert pls come
Hi all,
I have encountered a problem on PIX when using Web browser to access the FTP server.
On the log, it stated something like Deny MyIP/Some port to MyFTP/21 flag PSH ACK
Any one can help? Thanks.
5 Replies 5
Patrick Iseli
Level 7
Level 7
Have you seen this document:
Poor or Intermittent FTP/HTTP Performance Through a PIX
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094459.shtml
sincerely
Patrick
Hi Patrick,
Thx for your advise!
But what is the security risk for open port 113?
or is it my network using dual NAT problem?Because my network using PIX and W2k Router , is that any issue? pls advise.
Stanley
Hi Patrick ,
I have found that when i try to using third party
ftp client software to outside connect my inside ftp server , i found that using passive mode in client side didn't work , but try to active is work , in passive mode log , i check that in "PASV" this command timeout , i think is passive mode problem , and than in my PIX remove :
no fixup ftp 21
Also the error message is timeout , how can i solve in my PIX? pls advise.
Stanley
Have you opened also the tcp port 20 (ftp-data) in the outside access-list ?
example:
fixup protocol ftp 21
access-list acl_outside permit tcp any host FTP-Public eq 21
access-list acl_outside permit tcp any host FTP-Public eq 20
access-group acl_outside in interface outside
static (dmz,outside) FTP-Public FTP-DMZ netmask 255.255.255.255
What PIX OS version are you using? It is sure that the PIX OS 7.0 will solve some FTP issues with NAT/PAT environements.
sincerely
Patrick
Hi Patrick
I have tried your recommended access-list put my PIX, but same error
My PIX version 6.3 and model 515E
