01-30-2003 07:25 PM - edited 03-09-2019 01:55 AM
I have configured a router to initiate a vpn session upon start up using EzVPN config.
Think I got it configured successfully.
When it authenticate with a VPN 3060, on the telnet session to the router, I am being prompt to ket in the user name and password.
Is this how it should work??
02-05-2003 03:35 PM
Yeah thats how it would work.
Hope this helps,
Thanks and Regards,
Aamir Waheed,
Cisco Systems, Inc.
CCIE#8933
02-05-2003 05:00 PM
But this implementation is meant for end user to initiate a VPN tunnel without much technical knowledge.
If a telnet session into the router is needed to key in user id and password, then that is too "technical" for the user.
is there a way to make the prompt appearing on the end user PC/notebook?
