10-23-2006 12:52 AM - edited 03-09-2019 04:37 PM
Dear Sir,
I have 2 module FWSM on 2 Catalyst 6513. I have configure failover function. When I reboot module FWSM on Catalyst 6513 (standby), I see module FWSM on Catalyst 6513 (active) also down. You can look the configuration and show me the problem: This is the configuration of FWSM on Catalyst 6513 (active)
Failover On
Failover unit Primary
Failover LAN Interface faillink Vlan 53
Unit Poll frequency 15 seconds, holdtime 45 seconds
Interface Poll frequency 15 seconds
Interface Policy 1
Monitored Interfaces 8 of 250 maximum
failover replication http
Config sync: active
Last Failover at: 11:06:59 Oct 23 2006
This host: Primary - Active
Active time: 15720 (sec)
Interface outside (10.x.x.x): Normal
Interface inside (192.x.x.x): Normal
Interface security (10.x.x.x): Normal
Interface billing (10.x.x.x): Normal
Interface dmz-int (10.x.x.x): Normal
Interface voice (202.x.x.x): Normal
Interface management (202.x.x.x): Normal
Interface operation (10.x.x.x): Normal
Other host: Secondary - Standby
Active time: 255 (sec)
10-25-2006 12:53 AM
if anyone know the cause, please answer me early?
Thank you very much
10-25-2006 08:52 AM
How do you connect these 2 modules? Using a cross-over cable or a switch?
10-26-2006 08:16 PM
Using a cross-over
