failover warning (missing interface....)
a.youssef
Community Member
i had instaled 2 pix 525, when i activate failover its works but its shows the warning bellow:
( pix have 3 interfcaes : inside, outside and off)
WARNING, missing ip or failover address on off interface
WARNING, missing ip or failover address on inside interface
WARNING, missing ip or failover address on outside interface,
can you help me to anderstand what hapen?
9 Replies 9
lwierenga
Level 5
Level 5
Issue the "write standby" command on the active unit, this will force the entire configuration to memory on the standby unit.
Have you configured firewall with your failover IP addresses?
failover ip address outside a.b.c.d
failover ip address inside m.n.o.p
failover ip address off w.x.y.z
No the commande that i have used for activate FAILOVER are:
failover on
write standby
write memory
NB: 2 pix are configured as PASSIF/ ACTIF using Failover cable,
i do that but the same warnning appears aftres ~3 minutes
You need to issue your failover ip addresses. This document explains more about failover and what is required to configure it:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094ea7.shtml
i did that but nothing changes!!!
Can you post your config so we can spot the problem ?
a.youssef
Community Member
in order to post my config,I NEED YOUR E-MAIL PLEASE.
(for security reason).
thinks,
I'm waiting for your answer
my mail is: youssef.a@laposte.net
a.youssef
Community Member
notations:
x.y.z.X is my publics IP
aa.bb.cc is my domain:
this windows is taked before and after The Warnning message that we discuss about:
______________BEGENING of conf ____________________
myPix(config)# failover
myPix(config)# show failover
Failover On
Cable status: Normal
Reconnect timeout 0:00:00
Poll frequency 15 seconds
This host: Primary - Active
Acti
Interface outside (x.y.z.171): Normal (Waiting)
Interface inside (192.168.1.100): Normal (Waiting)
Interface off (127.0.0.1): Link Down (Waiting)
Other host: Secondary - Standby
Active time: 0 (sec)
Interface outside (0.0.0.0): Unknown (Waiting)
Interface inside (0.0.0.0): Unknown (Waiting)
Interface off (0.0.0.0): Unknown (Waiting)
Stateful Failover Logical Update Statistics
Link : Unconfigured.
myPix(config)# Sync Started
Sync Completed
myPix(config)# write standby
Building configuration...
[OK]
Sync Completed
myPix(config)# write mem
Cryptochecksum: xxxxxxx
[OK]
myPix(config)# WARNING, missing ip or failover address on off interface
myPix(config)# show conf
: Sa
: Written by enable_15 at 00:10:57.279 UTC Fri Jan 1 1993
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 off security50
enable password xxxxxxencrypted
passwd xxxxxxencrypted
hostname fireMET
domain-name aa.bb.cc
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
pager lines 24
mtu outside 1500
mtu inside 1500
mtu off 1500
ip address outside x..y.z.171 255.255.255.w
ip address inside 192.168.1.100 255.255.255.0
ip address off 127.0.0.1 255.255.255.255
ip audit info action alarm
ip audit attack action alarm
failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address ins
no failover ip address off
pdm location 192.168.16.1 255.255.255.255 inside
pdm location 192.168.16.2 255.255.255.255 inside
pdm history enable
arp timeout 14400
global (outside) 1 x.y.z.172-x.y.z.190 netmask 255.255.255.w
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
alias (inside) x.y.z.161 192.168.1.2 255.255.255.255
static (inside,outside) x.y.z.169 192.168.1.1 netmask 255.255.255.255 0 0
static (inside,outside) x.y.z.161 192.168.1.2 netmask 255.255.255.255 0
conduit permit icmp any any
conduit permit tcp host x.y.z.169 eq domain any
conduit permit tcp host x.y.z.161 eq www any
conduit permit tcp host x.y.z.169 eq smtp any
conduit permit tcp host x.y.z.169 eq pop3 any
conduit permit udp host x.y.z.169 eq domain any
conduit permit udp host x.y.z.169 eq 1434 any
conduit permit tcp host x.y.z.169 eq 1433 any
conduit permit tcp host x.y.z.169 eq imap4 any
conduit permit tcp host x.y.z.169 eq ftp any
conduit permit tcp host x.y.z.169 eq https any
route outside 0.0.0.0 0.0.0.0 x.y.z.170 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
_________________________END______________________
please i'm waitting you,
thinks a lot (merci beaucoup)
