09-06-2002 04:29 PM - edited 03-09-2019 12:12 AM
I have three questions
1) The ACL list I have configured on my outside interface, I thought should allow me to ping my router from an external location although I can not, Why?
2) All incoming traffic is being denied at the external interface right now but I would like to change this to allow some port though, specifically port 3389 to allow Terminal services on my Windows 2000 server. I have Nat configured on the router so I would like all outside traffic using port 3389 to be allowed through to internal network address 192.168.1.20. What is the best way to do this? I have tried several different things with my access list on the external interface but had no luck.
3) Should I apply the CBAC inspect rules on the internal interface instead?
I have attached my config file any help would be fantastic.
Cheers Ryan
Using 1723 out of 29688 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname %%%%%%%%%%%
enable secret 5 $1$PTeP$8xXkHun2tn70JotIyrDKv0
enable password 7 090D1F5A4B01161C4A0908
memory-size iomem 15
ip subnet-zero
ip inspect name JOJO tcp alert on
ip inspect name JOJO udp alert on
ip inspect name JOJO ftp
ip inspect name JOJO http
ip inspect name JOJO smtp
ip inspect name JOJO tftp
ip inspect name JOJO realaudio
ip inspect name JOJO h323
ip audit notify log
ip audit po max-events 100
ip ssh time-out 120
ip ssh authentication-retries 3
interface Ethernet0
description External Interface
ip address 164.164.164.3 255.255.255.248
ip access-group 101 in
ip nat outside
ip inspect JOJO out
half-duplex
no cdp enable
interface FastEthernet0
description Internal Interface
ip nat inside
speed auto
half-duplex
ntp disable
no cdp enable
ip nat translation timeout 3600
ip nat inside source list 1 interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 164.164.164.4
no ip http server
ip pim bidir-enable
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 101 deny tcp any any
access-list 101 deny udp any any
access-list 101 permit icmp any any unreachable
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any packet-too-big
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any traceroute
access-list 101 permit icmp any any administratively-prohibited
access-list 101 deny icmp any any
no cdp run
line con 0
line aux 0
line vty 0 4
password 7 01525757090F2601284942
login
no scheduler allocate
end
09-07-2002 12:28 AM
Answers to your queries inline;
Ans: since you have explicitly denied icmp any any on ACL 101, pinging from external localtion to the ethernet0 interface will not work, but since you have allowed echo-replies, ping through the router and from the router will work fine. You need to explicitly allow ICMP in your ACL 101 to work. Note that ICMP protocol does not get inspected by CBAC.
Ans: If you need to allow certain ports, that is just fine, you need to add an extra line on ACL 101 at the very top with a permit statement for port 3389.
Ans: your current config is ok, but yes, alternatively you can apply inspect inbound on the fastethernet0 interface, the effect will be same since you only have 2 interfaces on this router.
R/Yusuf
09-07-2002 07:33 AM
Thanks for your reply R/Yusuf I have some more questions though?
1)So I have to allow all ICMP traffic through in order to Ping my router from an external location?
2) If I allow port 3389 through, do I not have to point it to the correct internal address of 192.168.1.20? Also If I want to make changes to an existing ACL do I have to delete the whole ACL . I just wanted to know if there was a command to add a line to the TOP, Middle or Bottom of an ACL without deleting and recreating the whole thing.
Thanks again
09-08-2002 01:11 AM
answers inline
Ans: Yes, you haev to permit ICMP as it does not get inspected by CBAC
Ans: Yes you have to open ACL for correct IP and ports. If you have numbered ACL, then you cannot insert lines in between, you have to remove whole ACL and re-type. Best way is to copy it into notepad, remove it, and then paste it back. If you want the ability to insert in middle etc, then use Named access-list where you can modify/delete from the middle.
Yusuf
