Full Mesh IP Sec question
millerv
Need to do a fully meshed IPsec scheme among 5 sites
(probably with a pix) all sites have their own connection to the internet, and some form of NAT going on. All the unregistered addresses (inside)
are the same for each site. Using the sample
at www.cisco.com/warp/customer/110/pixmeshed.html
I'm wondering if i need to convince the customer
to modify their inside addresses to be site unique.
k.poplitz
Level 3
Level 3
Not only should they be unique at each site but they should also follow rfc1918 http://www.ietf.org/rfc/rfc1918.txt You can probably get by with some strange NAT setup but things can get very confusing and difficult to scale long-term.
Hope This Helps!
0sgruttadauria
Cisco's answer for fully meshed VPNs is to use MPLS, which really isn't VPN at all. It looks like a great solution, but not all ISPs support it and those that do charge more for the connection.
