05-27-2009 12:14 PM - edited 03-09-2019 10:19 PM
We have several FWSM in 2 6500 chassis and a few days ago the primary FWSM rebooted itself for unknown reasons and the secondary FWSM took over as planned.
But the primary FWSM has, after several days, switched back over to active automatically.
Question is, does anyone know why there would be such a long delay for the primary to request active mode?
05-27-2009 11:56 PM
There is no preemption support in Cisco FWSM (Or ASA/PIX for that matter) in Active/Passive mode. The primary most probably took over because something won't down on the 'Secondary (Active)' unit e.g. a monitored interface, triggering the failover. Check the output of the 'show failover history' command to see what exactly caused the failover.
In multiple context mode (Active/Active) you can configure pre-emption on a per context basis.
Please rate if helpful.
Farrukh
05-28-2009 08:14 AM
Thanks for your reply. This is the log output when the primary decided to take over as active:-
May 27 14:22:41 10.10.0.18 %FWSM-1-104002: (Secondary) Switching to STNDBY - Other unit want me Standby
May 27 14:22:41 10.10.0.18 %FWSM-1-104001: (Primary) Switching to ACTIVE - Set by the CI config cmd
Here is the failover history from the standby unit. It did not reboot like the primary did a few days ago.
Not Detected Negotiation No Error
Negotiation Cold Standby Detected an Active mate
Cold Standby Sync Config Detected an Active mate
Sync Config Sync File System Detected an Active mate
Sync File System Bulk Sync Detected an Active mate
Bulk Sync Standby Ready Detected an Active mate
Standby Ready Just Active Other unit want me Active
Just Active Active Drain Other unit want me Active
Active Drain Active Applying Config Other unit want me Active
Active Applying Config Active Config Applied Other unit want me Active
Active Config Applied Active Other unit want me Active
Active Standby Ready Set by the CI config cmd
Standby Ready Just Active HELLO not heard from mate
Just Active Active Drain HELLO not heard from mate
Active Drain Active Applying Config HELLO not heard from mate
Active Applying Config Active Config Applied HELLO not heard from mate
Active Config Applied Active HELLO not heard from mate
Active Standby Ready Other unit want me Standby
Cheers,
- Trevor
05-29-2009 06:48 AM
It seems the last failover was caused by someone issuing the 'failover active' command on the standby unit, or the 'no failover active' on the primary one, was that done by you?
Farrukh
