FWSM together switch 6500
r-barbosa
Beginner
Beginner
I am configuring a cisco 6509 switch with FWSM, but this a bit confusing to implement. I am following the following documentation http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00808b4d9f.shtml, however following the following configuration did not work. I would check if my understanding is correct. The FWSM firewall is like a part not working together with the switch, from what I saw on the configuration of the FWSM example conversation with the switch through a specific VLAN, and not together, am I correct? if so created because the configuration is incorrect? The next setting below.
switch 6500
interface vlan 10
ip address 192.168.10.1 255.255.255.0
FWSM
interface vlan 10
nameif outside
security-level 0
ip address 192.168.10.2 255.255.255.0
interface vlan 20
nameif inside
security-level 100
ip address 172.16.10.1 255.255.255.0
interface vlan 30
nameif dmz
security-level 60
ip address 172.16.20.1 255.255.255.224
not create any of the VLANs 10,20 and 30 on the switch 6500.
Jon Marshall
VIP Community Legend VIP Community Legend
Ricardo
"not create any of the VLANs 10,20 and 30 on the switch 6500."
All vlans must exist at L2 on the 6500. So if you do a "sh vlan" on the 6500 you should see vlans 10,20,30. If you don't then your setup will not work.
In addition you must have a L3 vlan interface for the outside interface which indeed you have from your config ie. -
switch 6500
interface vlan 10
But you must not have a L3 vlan interface for vlans 10 & 20.
Jon
Jon Marshall
Ricardo
switch 6500
interface vlan 10
Jon
Hi john
Its my configuration is correct. the error was in command "nat-control". I'm using routing only, no nat. I entered the command "no nat-control" and resolved.
regards.
Recognize Your Peers
