07-22-2003 12:22 PM - edited 03-09-2019 04:08 AM
Is it possible to have a dynamic destination with a GRE tunnel? I have one end of a tunnel that is assigned a DHCP address by a service provider and I want to use a GRE tunnel to connect this router to another router on the Internet.
07-22-2003 10:13 PM
This is possible with a new feature called Dynamic Multipoint VPN (DMVPN) in 12.2(13)T. See here for details:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t13/ftgreips.htm
It's designed for large hub and spoke environments where the spoke IP address is not known and to limit the config size of the hub, but it should be just as useful in your environment.
07-23-2003 07:08 AM
Thanks for the response. It looks like this method requires IPSec to run, and I just want to use GRE. Can this be used for GRE only? The software I have doesn't have the DES/3DES feature set.
07-23-2003 03:55 PM
This will work just with plain GRE, you don't have to encrypt it as well. Your hub (the router with the known IP address) would look like this:
interface Tunnel0
ip address 172.16.1.1 255.255.255.0
no ip redirects
ip nhrp authentication cisco123
ip nhrp map multicast dynamic
ip nhrp network-id 1
tunnel source Ethernet0/0
tunnel mode gre multipoint
tunnel key 10000
interface Ethernet0/0
ip address 10.1.1.1 255.255.255.0
and your spoke (the router doing DHCP), would look like this:
interface Tunnel0
ip address 172.16.1.2 255.255.255.0
ip nhrp map 172.16.1.1 10.1.1.1
ip nhrp map multicast 10.1.1.1
ip nhrp nhs 172.16.1.1
tunnel destination 10.1.1.1
tunnel key 10000
ip address dhcp
You can then run any routing protocol you like and include the 172.16.1.0 network under that routing protocol, that way routing updates will go across the tunnel and everything should be fine.
