Help needed with another smtp issue
subnet__zero
Here is my previous topology which worked good. Mail was coming in good.
CableModem -> PIX -> Switch
Had to switch to this because of VOIP box.
CableModem -> ATA (phone adapter) -> PIX -> Switch
ATA has the public address on the outside and inside = 192.168.0.1
PIX E0 = 192.168.0.2
PIX E1 = 10.10.1.1
Exchange Server is : 10.10.1.10
I can't seem to get mail in now even though the new public address is replicated in the public domain. Any help is appreciated. Here's my config.
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
no fixup protocol smtp 25
names
access-list out_in permit tcp any host 192.168.0.2 eq smtp
pager lines 24
logging on
logging buffered errors
logging history errors
interface ethernet0 10full
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside 192.168.0.2 255.255.255.0
ip address inside 10.10.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface smtp 10.10.1.10 smtp netmask 255.255.255.2
55 0 0
access-group out_in in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.0.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet 10.10.1.150 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
terminal width 80
mmorris11
Level 4
Level 4
Looks good to me. I assume that the 192.168.0.x addresses are placeholders for real internet addresses?
The only public address is on the internet port of the ATA (phone adapter) the 192.168.0.x addresses are private addresses. The 10.10.1.x addresses are on E1 of the PIX and back into the hosts on the network. HTTP traffic is coming and going fine. The only issue is with SMTP. I can send (of course) but not receive. When I do a "sh xlate" I see the 10.10.1.x traffic being translated to the 192.168.0.x range.
jmia
Level 7
Level 7
Franco,
Looking at your configuration, I presume that the IP address 192.168.0.0 /24 you have posted is so to hide your real internet routable IP address as you are posting on a open forum?
You need to use an internet routable IP address on your PIX outside interface i.e.
As an example:
ip address outside 212.205.xxx.101 255.255.255.248
route outside 0.0.0.0 0.0.0.0 212.205.111.102
The 212.205.xxx.102 is the internet facing router Ethernet address.
Now if you only have one public IP address available to you (212.205.111.101) and this address is being also used on the outside interface - as above, then yes you can use the keyword 'interface' on your static statement i.e.
access-list smtp_in permit tcp any host 212.205.xxx.101 eq 25
access-group smtp_in in interface outside
Static (inside,outside) tcp interface smtp 10.10.1.10 smtp netmask 255.255.255.255 0 0
You need to make sure that your MX record for smtp is also pointing to IP 212.205.111.101, i.e.
xyz.com MX preference = 5, mail exchanger = smtp.xyz.com
smtp.xyz.com internet address = 212.205.111.101
Of course when you have made the appropriate changes on your PIX and saved with: write mem - you need also to issue - clear xlate
Now if you telnet to IP 212.205.xxx.101 on port 25 from an external network you should get a response from your internal smtp exchange server.
If you have a spare public IP address available on the same IP range then use the spare IP for your smtp service and make the appropriate changes to your outside ACL and static statement, also to hide your PIX from any internet based scanners you can apply on your PIX:
In config mode
icmp deny any outside
Only issue deny icmp after your satisfied that all your internet-based services are working correctly.
You can test your PIX for any open 'holes' by going to http://www.grc.com and use the 'shields up' application to scan your network. One thing to take note here, is that if you are using the outside interface IP address for your smtp service then when you scan your network using the 'shields up' application it will show up as open for port 25 and hence may give any internet scanners information that your smtp port is open for abuse!
This is why I suggest that you use a different IP address for your smtp service and apply on the outside interface: icmp deny any outside, so that the PIX does not respond to any internet scanners.
You could also use the mail guard feature of the PIX but as you probably know, MS ESMTP servers have difficulty communicating if you use the mail guard feature!
I hope the above helps and let me know if you need any further help/assistance. Please rate posts - by rating posts will give an indication to the responder to your question that the information provided is correct and may help others who may be looking for similar answers!
Jay
Jay,
What I'm saying is that the "Linksys" phone adapter is working as the perimeter router. It has the ONLY public ip address on it's internet port and is 68.36.x.x It's ethernet port is PRIVATE and is 192.168.0.1
The PIX E0 is PRIVATE and is 192.168.0.2 and the PIX E1 is also PRIVATE 10.10.1.x I was wanting to get smtp through the "Linksys" and the PIX and to the smtp server on the 10.10.1.0 network. Since other services, ie: http, are coming through I'm looking for the right config to get the smtp to pass the PIX.
