how to block kazaa
taj
please how can i block kazaa and any other p2p on a cisco 3600 and cisco 1601 router ,first the kazaa was using the port 1214 but now it uses the port 80 too ..and the port 80 i needed for www ..so please help me to come over this problem.
thanks
yousef altaj
mostiguy
Level 6
Level 6
You can only block kazaa 2.0 by using NBAR on a cisco router.
osam
Yes, NBAR would be a good way of getting rid of all undestired applications..
Check the following link for more information on that..
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800c75d0.html
Does anybody have a working sample of controling Kazaa on a cisco 3640? Specifically I am wanting to LIMIT the amount of bandwidth that Kazaa/fasttrak like programs to a very small amount of bandwidth inititally and allow it to burst to use more bandwidth if the T1 is not very busy. Any help would be appreciated. Thanks
I sure wish Cisco would give us ISP's a working configuration that we could modify the amount of bandwidth on. I am sure that I am not the only ISP looking to limit the p2p bandwidth users.
