HOW TO BREAK PING
CSCO10685980
hello.
I send some pings on pix with IoS 7.0
pixfirewall# ping
Interface: inside
Target IP address: 10.40.4.1
Repeat count: [5] 100
Datagram size: [100]
Timeout in seconds: [2]
Extended commands [n]:
Sweep range of sizes [n]:
Sending 20, 100-byte ICMP Echos to 10.40.4.1, timeout is 2 seconds:
There is any key short cut to break sending??
THX
Laptom
pkhatri
Level 11
Level 11
Try the following:
ctrl-shift-6 all at the same time and then release and hit x.
Hope that helps - pls rate the post if it does.
Paresh
It works but on routers on pix platform doesn't.
Laptom
