How to configure a 515e
grw
Hello all,
I apparently am having some difficulties configure my 515e for my network. I have a DMZ interface on this machine as well.
I want to put my Web and Email on the DMZ and nothing else. When I set it up I can't get anything to pass properly so I am going to start over since there has been quite a few hands in the middle of this. Currently I just want to get the thing in the loop with everything open then I can setup my ACL's as I see fit.
Is there a good place to look at configs? I have 3 subnets one for the Int E0 (outbound.xx.xx.xx), DMZ (dmz.xx.xx.xx) and the one that feeds my internal lan. I think the issues are in my static routes but i'm not sure. I have successfully implemented a couple of 501's but they don't have a DMZ on them.
I have route outside 0.0.0.0 0.0.0.0 --> xxx.xxx.xxx.xxxx (being the my router address)
Then I have route inside gateway 255.255.255.255 ---> dmz address and i'm wondering if this is correct if it is then don't I need a rounte from the DMZ address to my internal Lan address? Any suggestions would be helpful as i'm not a routing/pix guru just trying to survive. TIA
ywadhavk
Here a good collection for the PIX config. The ones that you are interested is under the "Mail" section.
Hope that helps,
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Hardware:PIX&s=Software_Configuration#Software_Samples_and_Tips
yatin
Thanks looking at them now as I have to have this up in the next couple of days. :)
jmia
Level 7
Level 7
Hello Glenn,
Here's a link that might help out with your issues, the link is from a Cisco Guru and mentor.
http://www.netcraftsmen.net/welcher/papers/pix01.html
Hope this helps - and let me know how you get on.
Jay
