11-15-2002 10:34 AM - edited 03-09-2019 01:05 AM
I am new with Pix and I would like to enable SSL port 443 on my mail server using conduit command
Thanks in advance
11-15-2002 11:28 AM
I would suggest you go with access-lists, especially if this is a new install. If it's not, look into migrating to acls. Either way it will have to work with the static command.
eg.
access-list 101 permit tcp any host x.x.x.x eq 443 (where x.x.x.x is the IP of the server)
access-group 101 in interface outside
or
conduit permit tcp host x.x.x.x eq 443 any
Hope it helps.
Steve
11-15-2002 12:16 PM
Thanks for your prompt reply.
Its not a new install and we will need to migrate to access-list soon.
One more thing--
conduit permit tcp host x.x.x.x. eq https any
will the above static command also work??
11-15-2002 12:31 PM
The conduit statement is good but you will need a static as well:
eg
static (inside,outside) 200.200.200.200 10.1.0.1 netmask 255.255.255.255 0 0
static (inside,outside) 200.200.200.201 10.1.0.2 netmask 255.255.255.255 0 0
conduit permit tcp host 200.200.200.200 eq https any
conduit permit tcp host 200.200.200.201 eq https any
(where 200.200.200.x is the public IP and 10.1.0.x is your internal LAN).
Steve
11-15-2002 01:19 PM
Thanks for your explanation, that is all I was confused at!!
I wish to find experts like you all othr forums.
All the best to you!!
