How to terminate a connection thru a router?
akota
I have a 2621 router. Is it possible to monitor and manage connections thru the router? For example, I'd like to any connections being made thru the router to my webserver and, if need be, terminate those connections.
Any help would be appreciated!
ivillegas
Level 6
Level 6
I think you are looking for intrusion and detection kind of thing. In that case you have to certain extent you can use the Cisco 2621 with CBAC firewall. Else you hvae to go for Cisco IDS.
