I need a fix for CVE-1999-0524
davinci
Vulnerability name: CVE-1999-0524
Vulnerability scanner IDs: 10114
Description: ICMP information such as (1) netmask and (2) timestamp is allowed from arbitrary hosts.
Solution Name: ICMP Timestamp Request Remote Date Disclosure
Solution Description: Filter out the ICMP timestamp requests (13), and the outgoing ICMP
timestamp replies (14).
This vulnerability is on my IOS and IOS XE switches.
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 15.1(2)SY12, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Mon 23-Apr-18 10:15 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
xxxxxx uptime is 1 year, 3 weeks, 2 days, 23 hours, 7 minutes
Uptime for this control processor is 1 year, 3 weeks, 2 days, 22 hours, 39 minutes
System returned to ROM by reload at 17:00:48 CDT Fri Jul 20 2018 (SP by reload)
System restarted at 17:03:49 CDT Fri Jul 20 2018
System image file is "disk0:s72033-ipservicesk9-mz.151-2.SY12.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.5) with 458720K/65536K bytes of memory.
Processor board ID xxxxxxxxx
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
2 Virtual Ethernet interfaces
196 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
davinci
 FYI,  setup an ACL and applied inbound to resolve this vulnerablility
access-list xxx deny icmp any any timestamp-request
access-list xxx deny icmp any any timestamp-reply
access-list xxx permit ip any any
int xxx
ip access-group 123 in
davinci
int xxx
