ICMP (type 0 , code 0) in syslog
wasonce_2000
HI All,
I'm new to security and am finding several deined on inside interface access-list for ICMP (type 0 , code 0) from inside host > outside host. This is happening 24hr a day. The only thing I can see in log
is we are experencing ping sweeps from this IP block.
I have ran several trojan and virus scans from several different venders and return nothing on the inside host.
Is this a normal response from a inside host with a public interface on a single port? I do not allow icmp from internal host.
jmia
Level 7
Level 7
Mike,
If you have ACLs on the indside denying ICMP traffic from inside-to-outside then you'll see the syslog message you mentioned. Which PIX IOS are you running?
When you say you can see ping sweeps form this IP Block, is this a inside IP address?
Thanks - Jay.
nkhawaja
ICMP type 0 is ECHO-Reply. It seems like your inside hosts are sending lot of replies as a result of ECHO (Ping). We have seen this behavoiur as a result of the recent worms e.g. NACHI/BLASTER. If you are seeing this syslog message alot, you better need to apply access-list on the inside interface to block it, additionaly you need to inspect your hosts for the possibility of worms.
Nadeem
Nadeem, Do you have any sample config ACL to block ICMP Echo reply and log them..
Daya
lwierenga
Are you using any uptime and/or network monitoring software on the inside network?
