IMAP4 port does not work.
travis0
I have a pix501 and it's working fine. I am using access-list and static to open and forward ports 80, 443, 110, & 25 to servers. They are working fine. recently i allowed ports 143 and 993 to the firewall from outside.
Here is my configuration
access-list allowed_port tcp any host 11.22.33.44 eq imap4
static (inside,outside) tcp 11.22.33.44 imap4 192.168.2.2 imap4 netmask 255.255.255.255 0 0
access-group allowed_port in interface outside
I tested all other ports and they are ok except port 143. I used portping to ping 143 from the outside and it didn't work. I used portping to ping 143 from the inside of the network and it worked fine. so, i know the problem is the firewall. Anyone know why imap4 does not work on the pix501? Could it be my ISP is blocking port 143 on the external IP?
Thanks!
T.
bstremp
Level 2
Level 2
What version of software are you using in the pix?
