11-18-2003 12:53 PM - edited 03-10-2019 01:28 PM
In Pix 515 with 6.3(3), lots of alerts are captured as:
%PIX-2-106001: Inbound TCP connection denied from 209.104.39.100/80 to 209.183.x.x/64375 flags FIN ACK on interface outside
%PIX-2-106001: Inbound TCP connection denied from 203.176.60.90/80 to 209.183.x.x/64471 flags PSH ACK on interface outside
%PIX-2-106001: Inbound TCP connection denied from 203.176.60.90/80 to 209.183.x.x/64476 flags ACK on interface outside
%PIX-2-106001: Inbound TCP connection denied from 203.176.60.90/80 to 209.183.x.x/64476 flags PSH ACK on interface outside
%PIX-2-106001: Inbound TCP connection denied from 203.176.60.153/80 to 209.183.x.x/64478 flags ACK on interface outside
%PIX-2-106001: Inbound TCP connection denied from 203.176.60.153/80 to 209.183.x.x/64480 flags FIN PSH ACK on interface outside
%PIX-2-106001: Inbound TCP connection denied from 203.176.60.153/80 to 209.183.x.x/64481 flags ACK on interface outside
%PIX-2-106001: Inbound TCP connection denied from 203.176.60.153/80 to 209.183.x.x/64482 flags ACK on interface outside
I checked Cisco Output Interpreter that indicates it is related a failover, but actually there is no PIX Failover any more, and seems it is not attacks.
Any comments will be very appreciated.
11-18-2003 10:29 PM
do you have multiple routes to the internet?
Nadeem
11-19-2003 07:35 AM
Hi Nadeem,
There is only one default route to Internet detailed as the following cfg.
And both remote sites has the same issue after upgarded to image 6.3(3), but the Hub PIX is no problem.
cam-pixfirewall# sh run
: Saved
PIX Version 6.3(3)
interface ethernet0 10baset
interface ethernet1 10baset
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 5xK.V8i3.A4OSqwP encrypted
passwd 5xK.V8i3.A4OSqwP encrypted
hostname cam-pixfirewall
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 100 permit ip 10.20.3.0 255.255.255.0 10.20.1.0 255.255.255.0
access-list 100 permit ip 10.20.3.0 255.255.255.0 10.20.2.0 255.255.255.0
access-list 100 permit ip 10.20.3.0 255.255.255.0 10.20.6.0 255.255.255.0
access-list 100 permit ip 10.20.3.0 255.255.255.0 10.20.10.0 255.255.255.0
access-list 100 permit ip 10.20.3.0 255.255.255.0 10.20.11.0 255.255.255.0
access-list 100 permit ip 10.20.3.0 255.255.255.0 10.20.12.0 255.255.255.0
access-list 100 permit ip 10.20.3.0 255.255.255.0 10.100.0.0 255.255.0.0
access-list 100 permit ip 10.20.3.0 255.255.255.0 192.168.0.0 255.255.0.0
access-list 100 permit ip 10.20.3.0 255.255.255.0 host 205.184.244.56
access-list 100 permit ip 10.20.3.0 255.255.255.0 host 205.184.244.33
access-list 100 permit ip 10.20.3.0 255.255.255.0 10.20.4.0 255.255.255.0
access-list 110 permit ip 10.20.3.0 255.255.255.0 10.20.1.0 255.255.255.0
access-list 110 permit ip 10.20.3.0 255.255.255.0 10.20.6.0 255.255.255.0
access-list 110 permit ip 10.20.3.0 255.255.255.0 10.20.10.0 255.255.255.0
access-list 110 permit ip 10.20.3.0 255.255.255.0 10.20.11.0 255.255.255.0
access-list 110 permit ip 10.20.3.0 255.255.255.0 10.20.12.0 255.255.255.0
access-list 110 permit ip 10.20.3.0 255.255.255.0 192.168.0.0 255.255.0.0
access-list 110 permit ip 10.20.3.0 255.255.255.0 10.100.0.0 255.255.0.0
access-list 110 permit ip 10.20.3.0 255.255.255.0 host 205.184.244.56
access-list 110 permit ip 10.20.3.0 255.255.255.0 host 205.184.244.33
access-list 120 permit ip 10.20.3.0 255.255.255.0 10.20.2.0 255.255.255.0
access-list vpnnonat permit ip 10.20.4.0 255.255.255.0 10.20.3.0 255.255.255.0
access-list vpnnonat permit ip 10.20.3.0 255.255.255.0 10.20.4.0 255.255.255.0
pager lines 44
logging on
logging timestamp
logging buffered critical
logging trap notifications
logging history notifications
no logging message 106014
no logging message 106013
no logging message 106011
no logging message 304001
mtu outside 1500
mtu inside 1500
ip address outside 209.183.x.a 255.255.255.252
ip address inside 10.20.3.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm reset
ip local pool ipsecclients 10.20.4.2-10.20.4.100
no pdm history enable
arp timeout 14400
global (outside) 1 209.183.x.b
nat (inside) 0 access-list 100
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 209.183.x.c 1
timeout xlate 1:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
ntp server 128.100.100.128 source outside
ntp server 192.43.244.18 source outside
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt ipsec pl-compatible
crypto ipsec transform-set delta esp-des esp-md5-hmac
crypto dynamic-map users 40 set transform-set delta
crypto map deltamap 10 ipsec-isakmp
crypto map deltamap 10 match address 110
crypto map deltamap 10 set peer 209.183.x.x
crypto map deltamap 10 set transform-set delta
crypto map deltamap 20 ipsec-isakmp
crypto map deltamap 20 match address 120
crypto map deltamap 20 set peer 209.183.x.x
crypto map deltamap 20 set transform-set delta
crypto map deltamap 40 ipsec-isakmp dynamic users
crypto map deltamap client configuration address initiate
crypto map deltamap client configuration address respond
crypto map deltamap interface outside
isakmp enable outside
isakmp key ******** address 209.183.x.x netmask 255.255.255.255 no-xauth no-config-mode
isakmp identity address
isakmp client configuration address-pool local ipsecclients outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 1000
vpngroup vpnusers address-pool ipsecclients
vpngroup vpnusers dns-server 10.20.3.7
vpngroup vpnusers wins-server 10.20.3.7
vpngroup vpnusers default-domain abc.ca
vpngroup vpnusers idle-time 1800
vpngroup vpnusers password ********
telnet timeout 5
ssh timeout 15
console timeout 0
terminal width 80
Cryptochecksum:00000000000000000000000000000000
: end
cam-pixfirewall# sh ver
Cisco PIX Firewall Version 6.3(3)
Compiled on Wed 13-Aug-03 13:55 by morlee
cam-pixfirewall up 15 days 20 hours
Hardware: PIX-506, 32 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 8MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0004.2746.369a, irq 11
1: ethernet1: address is 0004.2746.369b, irq 10
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 2
Maximum Interfaces: 2
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Limited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
Serial Number: 480490238 (0x1ca3b2fe)
Running Activation Key: 0x084d5388 0xb2cd013b 0x9990061e 0x69c3b54c
Configuration last modified by enable_15 at 09:45:50.496 EST Wed Nov 19 2003
cam-pixfirewall#
106001: Inbound TCP connection denied from 194.109.6.92/80 to 209.183.130.73/26819 flags ACK on interface outside
106001: Inbound TCP connection denied from 62.221.192.66/80 to 209.183.130.73/26822 flags ACK on interface outside
106001: Inbound TCP connection denied from 62.221.192.66/80 to 209.183.130.73/26822 flags PSH ACK on interface outside
106001: Inbound TCP connection denied from 212.104.129.40/80 to 209.183.130.73/26827 flags ACK on interface outside
106001: Inbound TCP connection denied from 212.104.129.40/80 to 209.183.130.73/26827 flags PSH ACK on interface outside
106001: Inbound TCP connection denied from 216.19.67.187/80 to 209.183.130.73/26839 flags ACK on interface outside
106001: Inbound TCP connection denied from 216.19.67.187/80 to 209.183.130.73/26839 flags PSH ACK on interface outside
106001: Inbound TCP connection denied from 216.19.67.187/80 to 209.183.130.73/26840 flags ACK on interface outside
106001: Inbound TCP connection denied from 216.19.67.187/80 to 209.183.130.73/26840 flags PSH ACK on interface outside
106001: Inbound TCP connection denied from 216.19.67.187/80 to 209.183.130.73/26844 flags ACK on interface outside
What do you think?
04-26-2004 07:21 AM
In your toplogy, do the remote sites connect to the hub/central site for external access?
Is there a proxy server that your clients connect to for external access?
Can you run a two capture traces of a connection to 216.19.67.187 from a site that has this issue? Run one on an inside interface and run the other on the outside interface. I am interested if the tcp connection close that the client generates is propogated to the remote server, if it is then I would see a normal tcp close on both captures.
Let me know if you need help in setting up the capture.
04-24-2004 05:38 PM
Jack,
Did you ever get a resolution to this ? I believe I'm experiencing the same issue since upgrading from 6.2(2) to 6.3(3).
My posting on Apr 24, 2004 is called "After upgrade from 6.2(2) to 6.3(3) we see more denys". If you could take a look I'd really appreciate it.
Craig.
